Windows 11 Support Center. -
- HP Community
- Printers
- HP Officejet 7110 wide printer - problem with MARGINS
10-19-2015 02:32 PM
OK after all i got the officejet 7000 class driver to work on my officejet 7110 and tried all possible configuratioins on autocad but the problem remains...
First of all it turns so slow that i'd prefer to generate pdfs first than print from that driver.
second it still doesnt print with small margins all around, the closest i got was 3 small margins, the last one (the end bit) leaving still an unacceptable 25-30 mm
i really don't understand why there isn't a proper driver for a HP product i bought and am frustrated about the hours already spend on this. This should not happen with a HP product.
08-08-2019 12:17 PM
This is marked with [SOLVED]. Wheres the solution for this?
Even the support guy from HP can´t fix the A3 print without margins in autocad....
Is there a real solution for this or do we need to switch to other brand in other to get this working?
08-08-2019 12:23 PM
Hello,
Thank you for posting in this thread. Unfortunately based on when the last response was made, I have closed this thread to help keep comments current and up to date. We recommend starting a new thread for your issue by clicking here.
To be more helpful with your post, you can add key information if you desire:
1. Product Name and Number (please do not post Serial Number)
• Example: HP Pavilion DV2-1209AX or HP Deskjet 3000 Printer CH393A
2. Operating System installed (if applicable)
• Example: Windows XP, Windows Vista 32-bit, Windows 7 64-bit
3. Error message (if any)
• Example: ""Low disk space"" error in Windows
4. Any changes made to your system before the issue occurred
• Examples: Upgrading your Operating System or installing a new software; or installing new hardware like a printer, modem, or router.
If you have any other questions about posting in the community, please feel free to send me a private message!
Thank you
- « Previous
- 1
- 2
- Next »
