cancel
Showing results for
Search instead for
Did you mean:
    HP Solution Center Adobe Flash player error
    Please check this document to find the workaround solution for Print and Scan - HP Solution Center doesn't open
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Level 2
26 11 0 0
Message 1 of 2
55
Flag Post
HP Officejet Pro 276dw MFP has printing problem
Officejet Pro 276dw
Hello everyone
I have a problem with my printer
I sent a sentence to my printer. Instead of one sentence printed I got 3-4 same sentences printrd .
Could you, please, help me ?
Many thanks in advance for your kindness.
Best regards,
itsarinya
1 REPLY 1
HP Support Agent
HP Support Agent
9,141 9,115 614 684
Message 2 of 2
Flag Post
Hi @itsarinya,
I'd like to help!
To assist better -
  1. What's the application you are trying to print from? Have you tried printing from a different application or devices?
  2. Does the copy print out the same way?
  3. How is the printer connected to your device Wifi or USB
Meanwhile,
Let's try a power reset on the printer
Reset the product
With the printer turned on, disconnect the power cord from the rear of the printer.
Unplug the power cord from the wall outlet.
Wait at least 60 seconds.
Plug the power cord back into the wall outlet.
Reconnect the power cord to the printer.
Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
 Also, try updating the printer's firmware -HP Printers - Updating or Upgrading Printer Firmware
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
