Windows 11 Support Center. -
- HP Community
- Printers
- HP Officejet Pro 6978 will not print in color
06-12-2017 04:33 PM
I have reset the printer, I have even tried printing the test pages, but there aren't any colors coming out with it. Help me please!
06-13-2017 04:10 PM
Hi @TLynn93,
Welcome to HP Forums, this is a great place to get support, find answers and tips.
Thank you for posting your query, I'll be more than glad to help you.
I understand that you are unable to print in color from your HP ENVY 5640 e-All-in-One Printer.
This issue could occur if the print in black only option is checked in the drivers or the color cartridge may be empty or defective.
Let's go through a few steps to fix this issue.
1. In your software application, click Print.
2. Select your printer from the list of available printers.
3. Click the option that opens the Printer Properties dialog box.
Note: Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer Properties, Printer, or Preferences.
4. On the Properties window, click the Paper/Quality or Features tab, depending on your software.
5. Click Advanced, click Print in Grayscale, and then de-select Print in Grayscale or High-Quality Grayscale.
6. Click OK to complete the change.
If the issue persists, then you may follow the link: Color or Black Ink is Not Printing
Let me know how this works.
11-30-2017 12:29 PM
My HP OfficeJet Pro will not print in color. My last set of cartridges emptied and I replaced them. Now printer will not print in color. I've checked all of the boxes for color and grayscale, I've removed and reinstalled the cartridges, I've reinstalled the printer software, I've unplugged printer, etc. Nothing so far has worked. I'm ready to change to Epson.
04-19-2018 03:10 PM - edited 04-19-2018 03:23 PM
I had this problem. Printer had crashed/frozen during installation.
I was able to reset the the prinbter by putting the old cartridges back in. Letting them load, then replacing them again.
03-25-2019 09:05 AM
I am glad everything is up and running.
Do get back to us in the future for any further assistance.
Thanks 🙂
TEJ1602
I am an HP Employee
