Thanks for the reply, the procedure is the same for all the products. As I mentioned earlier, it is up to you whether you want to continue using the printer as it is. Or you can reinstall the printer in the manner suggested.
Please do reply if you need any further assistance.
Chimney_83
I am an HP Employee
Quick update here for this post.  After weeks now of careful monitoring and usage, I am pleased to state that we have found a solution:
DO NOT INSTALL HP SOFTWARE!!!  Instead, simply use default Windows 10 drivers.  Installing HP software introduces a liability and creates all sorts of issues.  In our environment, at least.
By simply using default installation and drivers on all our Windows 10 machines, we have been operating smoothly without interruption or any funny business.  So, long story short: HP software is the problem and should be avoided at all costs.
Thank you all again for your assistance.
