HP Smart Tank 530 will not print black ink. Please Help
1 REPLY 1
Hi @Wium,
I'd be happy to help you!
I understand that you are having issues with the printer not printing black.
Perform the following tasks in the order given. Use the printer after each task to see if the issue is resolved.
Check ink levels and fill ink tanks
Low ink levels can impact print quality. Refill any tanks that are low on ink.
HP recommends that you use genuine HP ink. HP cannot guarantee the quality or reliability of non-HP ink. If you do not use genuine HP ink and HP printheads, the steps in this document might not resolve print quality issues.
NOTE:
On the control panel, look for KYMC and the blinking Ink icons . The Printhead icons might also blink.
Fill any tanks that are low on ink.
Refilling ink tanks
Click here for the remaining steps.
Update the firmware. Click here
Hope this helps! Keep me posted for further assistance
Please mark this post as Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Nal_NR-
HP Community Moderator
