The printer is not on but when i try to switch it on - the following lights are blinking -
- resume job
- information
- catridge
- power
and it is flashing E in the display and blinking.
Only thing am able to do is switch it off. Can you please help what to do?
1 REPLY 1
Hi @Narsir,
I'd like to help!
I understand you are receiving an "E" error and the icons on the printer are blinking.
Try the below suggestions
Reset the product
With the printer turned on, disconnect the power cord from the rear of the printer.
Unplug the power cord from the wall outlet.
Wait at least 60 seconds.
Plug the power cord back into the wall outlet.
Reconnect the power cord to the printer.
Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
Try updating the printer's firmware -HP Printers - Updating or Upgrading Printer Firmware
Also, try the steps under the relevant tab in the document -Blinking Lights
If the issue persists, I'd suggest you contact HP in your region regarding the service options for your printer
And, Welcome to the HP Support Community.
Click the “Yes" on the bottom right to say “Thanks” for helping
