I have printing problem with HP laser jet m1132 mfp printer.
The cartridge drum unit is not turning leading to paper jamming problem.
I used different 85A cartridges but the problem persist.
I clean paper pickup assembly but the problem persist.
I will be grateful for your kindly response.
Thanks.
Hi @SandaSH1,
Thank you for posting your query. I will be glad to help you.
I understand your situation. Here’s how to address the issue with your HP LaserJet M1132 MFP, where the cartridge drum unit is not turning, causing paper jams, even after trying multiple 85A cartridges and cleaning the paper pickup assembly.
1. Inspect the Cartridge Drum Gear
  • Remove the toner cartridge.
  • Rotate the drum manually (gently) using the exposed gear.
  • If it doesn’t rotate smoothly or feels stuck, the cartridge may be defective even if new.
2. Check the Printer Drive Gear
  • With the cartridge removed, look inside the printer where the cartridge gear would engage.
  • Use a flashlight to inspect for broken teeth or misalignment.
  • If the gear is damaged, it may require professional service.
3. Clean Internal Paper Path and Rollers
4. Try a Known-Good Genuine HP 85A Cartridge
  • If possible, test with a verified working HP cartridge from another printer.
  • This helps rule out cartridge-specific issues.
5. Run HP App
I hope this helps.
Take care and have an amazing day!
Did we resolve the issue? If yes, please consider marking this post as "Accepted Solution" and click "Yes" to give us a helpful vote - your feedback keeps us going!
Regards,
VikramTheGreat
3 REPLIES 3
Hi @SandaSH1,
5. Run HP App
I hope this helps.
Regards,
VikramTheGreat
There is no problem with my cartridge.
I can scan but I cannot print.
