cancel
Showing results for
Search instead for
Did you mean:
    Know the Benefits of your HP account
    Connect with HP support faster, manage all your devices in one place, view warranty information and more– Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Highlighted
New member
1 0 0 0
Message 1 of 2
71
Flag Post
HP officejet Pro 8100. Power button is blinking and printerhead icon is on.
HP
Did everything that HP support had online but the problem is persisting. does that mean I need to go and buy a new printerhead?
1 REPLY 1
Highlighted
HP Support Agent
HP Support Agent
23,999 23,889 1,321 1,406
Message 2 of 2
Flag Post
@neile9
Welcome to the HP support community.
Make sure the printhead is installed correctly
  1. Press the Power button to turn on the printer, if it is not already on.
  2. Open the ink cartridge access door and the printer lid. The carriage moves to the center of the printer. Wait until the carriage stops in the center of the printer before you proceed.
    Figure : Open the ink cartridge access door and the printer lid
    Image: Open the ink cartridge access door and the printer lid.
  3. Disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Remove the printhead. You can leave the ink cartridges in the printhead. Lift the lever on the back right corner of the printhead assembly, and then lift out the printhead.
    Figure : Remove the printhead
    Image: Remove the printhead.
       CAUTION:
    Do not touch the electrical contacts or the nozzles on the printhead with your hand or fingers. Touching these areas can cause electrical failures or print quality problems. Do not leave the printhead out of the printer for more than a few minutes.
    Figure : Do not touch the electrical contacts or nozzles on the printhead
    Image: Do not touch the electrical contacts or nozzles on the printhead.
  6. Clean the printhead contacts with a cotton swab.
    Figure : Clean the printhead contacts
    1. Contacts: Clean
    2. Nozzle: Do NOT clean
  7. Grasp the printhead on both sides with the electrical contacts facing the rear of the printer, and then insert the printhead into the carriage.
    Figure : Reinsert the printhead
    Image: Reinsert the printhead.
  8. Carefully lower the latch handle on the carriage to secure the printhead.
  9. Close the printer lid and ink cartridge access door.
  10. Reconnect the power cord to the rear of the printer.
  11. Plug the cord back into the wall outlet.
  12. Press the Power button to turn on the printer.
You can refer this HP document for more assistance:- Click here
I hope that helps.
To thank me for my efforts to help you, please mark my post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
