To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
HP smart tank 5100
Issue with carriage moving fast side to side and banging off side then error code E3 comes up ,no visible blockages and moves freely by hand ,
1 REPLY 1
Hi @Derek1973,
I'd be glad to help you!
I understand you are facing issues with error E3.
Perform the following tasks in the order given. Use the printer after each task to see if the issue is resolved.
Check for obstructions in the carriage path
  • Remove any loose paper or obstructions that might be blocking the carriage path.
  • If the Cancel button on the control panel is lit, press it and wait until the printer is silent.
  • Turn off the printer and disconnect the power cord.
  • Open the cartridge access door to get to the carriage inside the printer.
Examples of a cartridge access door
Examples of printer door locations
  • Make sure the carriage is not obstructed by gently sliding the carriage side to side.
  • Look for and remove any obstructions in the carriage path, such as crumpled paper or dislodged labels.
  • CAUTION:
  • Do not tilt an ink tank printer when attempting to remove obstructions as ink might spill.
Example of a printer with an obstruction in the carriage path
Example of a printer with paper debris in the carriage path
  • If the carriage has a latch, gently press it down to make sure it is locked into place.
  • CAUTION:
  • If the carriage latch of an ink tank printer is secured, do not press down on it to avoid printer damage.
Examples of the carriage latch
Example of the carriage latches
  • If the carriage is not locked in place, move it to each side, removing any obstructions blocking its path.
  • CAUTION:
  • Do not force the carriage to move if it is locked or stuck. This can damage the printer.
  • Close the printer door.
  • Reconnect the power cord and turn on your printer.
Click here for the remaining steps.
Hope this helps! Keep me posted for further assistance
Please mark this post as Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
Nal_NR-Moderator
I am an HP Employee
