1
Windows 11 Support Center. -
1
- HP Community
- Printers
- How can I print borderless using an HP Color LaserJet Pro M4...
2 REPLIES 2
12-07-2023 11:20 AM
The only way to do this with a laser printer would be to print on a larger sheet of paper and physically cut it down to the photo size you want. @Valsimot is correct that you cannot print borderless directly on paper with laser.
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
Ask the community
