HP Photosmart 5515 e-All-in-One Printer - B111h
Microsoft Windows 10 (32-bit)
How to fix print-heads slamming into the left on powerup
1 REPLY 1
There is a plastic strip that runs across the printer that is printed with a grid that is read by a sensor in the carriage to track movement.  If that  strip is dirty or damaged the sensor cannot read properly and blindly moves the printhead. Clean the strip with a damp lint free cloth. Water only, no chemicals. If it is disconnected you will need to reinstall it if it is not damaged. Typically a slot in the plastic goes over a hook. If the end is broken you may be able to create a new slot with duct tape.
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
