To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
HP ENVY Pro 6455 All-in-One Printer
How do I order a replacement paper tray? One of the plastic tabs in back of tray broke off. So when the tray is closed the printer says the tray is open.
1 REPLY 1
@Mari1865,
Welcome to our HP User Forum!
Your HP ENVY Pro 6455 All-In-One Printer (5SE45A) according to: http://h10032.www1.hp.com/ctg/Manual/c06584213.pdf and: https://partsurfer.hp.com/partsurfer?searchtext=5SE45A, requires HP p/n: 4LW49-60004 ("ASSY - Document Feeder Input Tray"). Alternative p/n: 4LW49-60040.
However, ordering this part in the US appears to be problematic, as I did not find a single source (including eBay) to purchase it from.  Only in the UK you may be able to order it: https://www.lambda-tek.com/HP-4LW49-60004~sh/B45584714.
Kind Regards,
NonSequitur777
