Ink tank 415
Android 7.0 - 7.1.2 Nougat
Hello, i guess this was asked before but it didn't really help me. I have bought yesterday a hp ink tank 415 printer and once i finished setting it up i started hearing an annoying beeping sound that never stops unless i am printing something or having the printer front cover open where the printheads are, I've updated my printer firmware to the latest and it still beeps. Thanks
@HasseneSoua
Welcome to HP forums, I see that you are getting beep sound on the printer.
Reset the printer.
  1. Turn on the printer.
  3. Disconnect the USB cable from the rear of the printer. If your printer has a network or wireless connection, leave it connected.
  4. Remove the ink cartridges from the printer.
  5. With the printer turned on, disconnect the power cord from the rear of the printer and from the wall outlet or power strip.
  6. Wait at least 60 seconds.
  7. Plug the power cord back into the wall outlet.
    NOTE:
    HP recommends connecting the printer power cord directly to a wall outlet.
  8. Reconnect the power cord to the rear of the printer.
  9. Turn on the printer, if it does not automatically turn on.
    The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
  10. Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
  11. Reinsert the ink cartridges, and then close the ink cartridge access door.
  12. If you receive a prompt to print a calibration page, do so.
  13. If you disconnected the USB cable, reconnect it to the rear of the printer.
  14. Try to print.
Let me know how it goes.
To thank me for my efforts to help you, please mark my post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
3 REPLIES 3
Small edit: i also did the reset but it didn't change anything
@HasseneSoua
Reset the printer.
    NOTE:
  14. Try to print.
Cheers.
Sandytechy20
I am an HP Employee
I follow all the steps and at the end all strange sounds disappered.
I have a wierd problem with printhead, but after I replaced it everything is fine.
