Windows 11 Support Center. -
- HP Community
- Printers
- I click print and it takes around 2 minutes for the printer ...
06-04-2020 01:40 AM
I have tried everything that is suggested on the internet and it's still taking almost 2 minutes to print a document from when I click print. This is the same if I put a document on the scan location then select copy from the user interface on the printer
06-09-2020 03:31 PM
Thank you for posting on HP Support Community.
Don't worry as I'll be glad to help, I have a few troubleshooting steps we could try to fix the issue:
Resetting the printer can resolve some types of slow printing issues.
With the printer turned on, disconnect the power cord from the printer.
Unplug the power cord from the power source.
Wait 60 seconds.
Reconnect the power cord to a wall outlet and to the printer.
If your printer is connected to a wired or wireless network, there are several tips that might resolve slow printing issues.
On your computer, check the wireless signal strength by clicking the wireless connection icon in the Windows task bar. If the signal strength is low, move the router, computer, and printer closer together.
Make sure there are no additional strains on your network, such as downloading or streaming services. Depending on your bandwidth, these activities can significantly affect print speed.
If the printer is connected to the network with an Ethernet cable, make sure the cable connections are secure.
Restart your router by unplugging it, waiting 10 seconds, and plugging it back in.
Hope this helps! Keep me posted for further assistance.
ECHO_LAKE
I am an HP Employee
