Windows 11 Support Center. -
- HP Community
- Printers
- I have problem with double sided printing.
05-01-2021 01:56 AM
Hello, I have problem with my printer. Before it printed double sided automatically but now suddenly it turn to manually printing mode. I can´t change this even I have tried many times. When I go to Customize printer and there I can see this in printer setup: automatic double sided printing installed. When I try to print double sided paper it turn to manually flip. Can someone help me? I have deleted all HP programs and uninstalled my printer and installed it again but it does not help.
Susan From Finland...
Solved! Go to Solution.
05-02-2021 06:37 AM
Hi,
Try following below specific version of the HP Print and Scan Doctor Utility by selecting your printer:
http://ftp.hp.com/pub/printers/hppsdr/patches/HPPSdr.exe
Be sure to restart your PC and allow the utility to complete the process, then check for any difference.
Try printing and check for any change, if the same remains try printing using the newly added print queue copy with your printer model and check for any difference, you should see an extra print queue with your printer name in the list.
Shlomi
Click the Yes button to reply that the response was helpful or to say thanks.
If my post resolve your problem please mark it as an Accepted Solution 🙂
05-02-2021 06:37 AM
Hi,
Shlomi
