To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
I need help setting up my 8020 printer to print borderless
4 REPLIES 4
@JJ717
Welcome to the HP Community --
Printer = one of
Results for "8020 printer" (4)
Example - Product selected as example
HP OfficeJet Pro 8020e All-in-One Printer series
Category Product Specifications > Topic Product Information
Sample
Product Specifications for the HP OfficeJet Pro 8020e All-in-One Printer (229X1D)
Paper handling
Input capacity
Up to 225 sheets
Standard input capacity (cards)
Up to 60 sheets
Standard input capacity (envelopes)
Up to 10 sheets
Output capacity
Up to 60 sheets
Media sizes supported (metric)
A4, A5, A6, B5(JIS), Card (A4, Hagaki, O**bleep**u Hagaki); Photo (13 x 18 cm, 10 x 15 cm); Envelope (A2, C5, C6, DL. Chou #3, Chou #4); 8.5 x 13 in
Media sizes supported (U.S. standard)
Letter; Legal; Government Legal; Executive; Statement; 4 x 6 in; 5 x 7 in; 13 x 18 cm; 8 x 10 in; 10 x 15 cm; L; Photo 2L; Envelope( #10, Monarch, 5.5 bar); Card (4 x 6 in, 5 x 8 in)
Media sizes, custom (metric)
Tray 1: 76.2 x 127 to 215.9 x 355.6 mm
Media sizes, custom (U.S. standard)
Tray 1: 3 x 5 to 8.5 x 14 in
Media types
Plain Paper, HP Photo Papers, HP Matte Brochure or Professional Paper, HP Matte Presentation Paper, HP Glossy Brochure or Professional Paper, Other Photo Inkjet Papers, Other Matte Inkjet Papers, Other Glossy Inkjet Papers, Thick Plain Paper,Light/Recycled Plain Paper,HP Tri-fold Brochure Paper, Glossy
Media weight supported (metric)
60 to 105 g/m² (plain); 220 to 280 g/m² (photo); 75 to 90 g/m² (envelope); 163 to 200 g/m² (card)
Media weight supported (U.S. standard)
16 to 28 lb (plain paper); 60 to 75 lb (photo); 20 to 24 lb (envelope); 90 to 110 lb (card)
Borderless printing
Yes, on photo paper only, up to 8.5 x 11 in (US letter), 210 x 297 mm (A4)
Example - HP Smart - Windows - Simple Photo Print = 4x6 inch - Borderless
HP_Smart_Win_Print_Photo_4x6_All_3HP_Smart_Win_Print_Photo_4x6_All_3
Example - HP Smart - Mobile - iOS / iPadOS - Photo Print
Sample shows "Fit" - For your Job and a supported paper size / type, change Size Option setting to "Fill"
HP_Smart_Mobile_Image_Print_Resize-Move_10HP_Smart_Mobile_Image_Print_Resize-Move_10
References / Resources
HP Printer Home Page - References and Resources
Learn about your Printer - Solve Problems
Categories: Alerts, Troubleshooting, Ink & Paper, HP Software / Drivers / Firmware Updates , Setup & User Guides, Product Specifications, Account & Registration, Warranty & Repair
Open
 Product Home - Printers
 Enter the device type and model name of your HP product
OR
 Select a saved product from HP Account Dashboard
OR
Printer = one of
Thank you for participating in the HP Community --
People who own, use, and support HP devices.
Click Yes to say Thank You
Question / Concern Answered, Click my Post "Accept as Solution"
Dragon-Fur
Only on photo paper?? That stinks!
Can you select photo paper as your media, but not actually use photo paper? I'm needing to print borderless on legal size paper.
I'm on a Macbook Pro OS 14
@JJ717
Edit / Update
If you wish to try it,
If your MacOS software supports it and the options will work out,
  • Pack that print image into a Document - Print at size and trim
OR
  • Export the Document to PDF and print that file >>
  • Favorite print software OR perhaps Adobe Reader DC -
  • Print at the size you want on the supported paper size / type
  • Note that Adobe will print at any size you want, including Poster that can be spread across more than one sheet of supported paper.
  • Trim the edges with a paper cutter.
NOTE
If you don't have a paper cutter, you can likely get one at a local office supply store or online (for example, Amazon).
Original Content
OK -
We crossed each other's posts.
Although the examples in my first post do not directly apply to your MacOS, the answer is the same.
The limitation is hardware, not software.
No, you cannot select photo paper when you are not actually using photo paper.
We don't control the answers, of course.
I wish you could have what you want.
Dragon-Fur
I am trying to print from QuarkXpress. I have created a PDF and tried printing from that, but it still isn't borderless. I suppose I will just have to have them printed elsewhere. This is really disappointing because my last HP would print borderless. If I had known that this one didn't, I would never have bought it. Sorry, HP,  you've let me down.
