I have the same problem with the Laser Jet CP3525n. At bootup I hear a grinding noise and right after initialization,  the printer throws the 59.F0 Error Code. I've replaced the transfer belt once.  I
tend to agree with another user that it may be the main drive assembly and would like to give it a shot. Does anyonWhat's the manufacturer's part #?
1 REPLY 1
Rather than replace the drive assembly, you first want to try repairing the solenoid in the drive assembly as this is the most common cause of the 59.f0 error on this model.
https://www.youtube.com/watch?v=Bpwu8hRWBko
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
Here's a video that shows you a shortcut when fixing the sticky transfer belt solenoid in half the time.
