Windows 11 Support Center. -
- HP Community
- Printers
- Ink Carriage will not move to center when access door opened...
08-09-2017 09:49 AM
Just received the printer from work. Downloaded the software straight from HP.com and had no problems. I need to install new ink because those in it are old and empty. When I open the access door the carriage does not move to the center so I can remove and replace the ink cartridges.
08-09-2017 02:51 PM
Can you move the cartridge holder by hand, remove the power cord first.
Please mark the post that solves your issue as "Accept as Solution".
I am a volunteer and do not work for HP.
12-06-2018 11:59 AM
Is your warranty over?
12-06-2018 04:20 PM - edited 12-06-2018 04:23 PM
Contact HP:
Step 1. Open link: www.hp.com/contacthp/
Step 2. Sign in or select Printer
