I have an HP 8600 printer. I had been using non-standard ink cartridges without problem for a long time. Now I get the message that says there is a problem with the printer or ink system. Turn off printer and turn on and if problem persists contact HP. I have changed all the cartridges I have checked for leaks. I have hard reset the printer. I have done everything I can think to do. Can anyone help? Should I just go by real HP cartridges or will that be a waste of money at this point and I should just get a new printer?
1 REPLY 1
@TBB1130, Welcome to HP Support Community.
I understand how frustrating it can be to encounter an "Ink System Failure" message, especially after trying multiple troubleshooting steps. Let's work through this together.
This error typically occurs due to:
  • Incompatible or damaged ink cartridges
  • Clogged printhead
  • Firmware issues
  • Internal hardware faults
Since you've already tried a hard reset and checked for leaks, here are some additional steps to try:
Step-by-Step Troubleshooting
Use Genuine HP Ink Cartridges
Non-HP cartridges can sometimes trigger system errors, especially after firmware updates. Try replacing all cartridges with genuine HP 950/951 cartridges.
Which cartridges work with my HP printer? | HP® Support
Clean the Printhead
If ink has dried or clogged the printhead, it can cause system errors.
  • On the printer control panel, go to: Setup > Tools > Clean Printhead
  • Run the cleaning cycle 2–3 times if needed.
Update Printer Firmware
Outdated firmware can cause cartridge recognition issues.
Visit the HP Software & Driver page: Official HP® Drivers and Software Download | HP® Support
Download and install the latest firmware for your model.
We strongly recommend you use HP cartridges.
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Select "Yes" on the bottom left to say “Thanks” for helping!
Max3Aj
HP Support
