Windows 11 Support Center. -
- HP Community
- Printers
- Ink tank 315 does not turn on, only resume and print head in...
07-25-2021 09:46 PM - edited 07-25-2021 09:47 PM
I have this issue this morning were only resume and print head indicator are lit and not blinking when plugged and none of the given solution fixed it. Is there anyway to by pass of fix this? and why is it acting like this?
07-29-2021 11:11 AM
Thank you for posting on the HP Support Community.
Don't worry as I'll be glad to help, however, to provide an accurate resolution, I need a few more details:
- Did you make any changes to your printer?
- Are you getting any error messages or codes?
- What are the troubleshooting steps you have tried so far?
While you respond to that, let's try these steps:
- With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
- Remove USB cable, if present.
- Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
- Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord (This is important) and then plug back the power cord to the printer.
- Turn on the printer and wait till the warm-up period finishes and the printer is idle.
Hope this helps! Keep me posted for further assistance.
ECHO_LAKE
I am an HP Employee
07-29-2021 09:26 PM
To answer your questions Echo_Lake;
- Did you make any changes to your printer? : none, never been touched or altered.
- Are you getting any error messages or codes?; No, no power or display at all. (see image) once unit is plugged in to any outlet source the resume and print-head lit up steadily.
- What are the troubleshooting steps you have tried so far?: The one you provided below since that is the only troubleshooting I found prior to my post.
07-30-2021 01:07 PM
Thank you for posting back.
This looks like hardware related issue with the printer. Please reach out to our HP Support in your region regarding the service options for your printer. HP Support can be reached by clicking on the following link: www.hp.com/contacthp/
Hope this helps!
ECHO_LAKE
I am an HP Employee
