Windows 11 Support Center. -
- HP Community
- Printers
- Re: LJ 452DN does not print color on engine test
08-12-2022 03:23 PM - edited 08-12-2022 03:33 PM
After installing new OEM transfer belt, old firmware and upgraded firmware only black prints - no colors print. Engine test no colors only black. Old transfer belt now does not print color only black. Printer is not connected to pc, all tests are from the control panel. Intermittent 49 error
08-12-2022 03:30 PM
When removing the belt there are two white locks that you pull out to allow the belt to be removed. These two locks engage the alienation system and if not seated properly afterwards, the belt gets locked in black only mode.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
08-12-2022 11:48 PM
You do need to make sure that they engage in drive slots in the belt mechanism as well.
