I get the blinking light error in less than 2 h as soon as the printer is online. Very boring.
My issue still remains...
I've tried a few solutions but none helped.
Sound to me like a faulty update or alike.
It will be great if HP will help to solve this annoying issue....
I have this issue as well.  It appears that this is more than just an isolated incident.  I would like to be informed of any updates regarding this as well.
I had direct phone contact to the HP support in the meantime. Very friendly, fast and comprehensive indeed. But obviously tapping in the dark as well: tried the DHCP thing with me, which not really solved the issue as we already know. Might be, the duration till the effect occurs is some hours longer. Difficult to say.
 My guess is a bug located in the April 21 Firmware.
Hopefully we get a fix for this soon!
 Thomas
The issue has come back after three weeks!
HP is too big to SUPPORT.  This is the way they get you to BUY A NEW PRINTER!!
Have the same problems. Working with a mac. Please let me know what to do.
I just applied your Manual IP solution to my HP OfficeJet Pro 8720's flashing disease. Fingers crossed, but so far, no flashing. Thanks for your clear and easy-to-follow solution.
I tried Print and Scan Dr first, but everything had a green checkmark and its software, which is set to auto update, was up to date.
Next, I printed out its network info and followed your truly clear steps to enter the manual IP address through my web browser. Again, thank you very much as I was having to rescue my printer numerous times every day.
If the problem returns, I'll update this post, but if you don't hear from me again, all is well in my little network's printer land
Hello again,
Sadly, I tried both of your suggestions two times through, and my Officejet Pro 8720 still enters the "all lights blinking with blank screen" state at least 4 times a day. So far, when I push the power button while it's doing this, it then basically restarts and after a brief time of print heads moving it's ready to go.
This isn't good, nor is it fun to have to keep stopping my work to go reset the printer this often each day.
Is this a sign that the printer is dying? I certainly hope not as it's only around 3 years old and was purchased new.
I've always had good luck with HP printers, and I've had several over my 35 years of Desktop computing, so I'm hoping that you can supply me with another fix to try
Hi, I'm experiencing the same thing.
It happens something like every 2-4 hours, i cant tell exactly.
i've seen this intermittent over the years with this printer, probably once every second month last two years, but then now, for 1-2 months, it's happening multiple times every day.
reach out if any additional details are required.
