Chrome OS
My Hp 7155 printer will not print and states 'printer filter failed' either via USB or wireless from both my chromebook and my Android phone. It'd at times print just one page and then stop. Even after restarting all devices. Been happening the last couple of days. Please help!
1 REPLY 1
Hi @1JoRay,
Welcome to the HP Support Community
I understand you are facing an issue with your HP 7155 printer. Not to worry I will help you to get a resolution to resolve the issue.
Let's perform a power drain:
  • With the printer turned on, disconnect the power cord from the rear of the printer and also unplug the power cord from the wall outlet.
  • Remove the USB cable, if present.
  • Wait for 2-3 minutes, press and hold the power button on your printer for about 30 seconds to remove any additional charge.
  • Now plug back the power cable straight to a wall outlet without any surge protector or an extension cord (This is important) and then plug back the power cord to the printer.
  • Turn on the printer and wait till the warm-up period finishes and the printer is idle
Update the printer firmware
  • Click here to download and install the latest printer firmware from your product
  • Click here to know different methods of updating the printer firmware.
  • For assistance with printing from Chromebook, refer to - HP printer setup (Chromebook)
If the issue persists, then please follow the steps mentioned in this document:
A_Gayathri
HP Support Community Administrator.
