Envy Photo 6255
My printer will scan and copy.
When I try to print I get one or two lines of characters per page.  It will print this way until paper is out.  The only way to stop this is turn off the printer.
I have deleted and installed the correct software with no help.
Printing wireless.
1 REPLY 1
@curt1026
Welcome to the HP support community
I understand that you are getting printing issues on the printer, I am glad to assist you.
Are you getting any error messages?
Did you uninstall the printer from the root level before installing the new driver?
Meanwhile:-
Perform root level uninstallation to remove all the printer related software's.
  • In Windows, search for and open Programs and Features.
  • Select your HP printer.
  • Select Uninstall.
  • In Windows, search for and open Devices and Printers.
  • In the Devices and Printers window look for your HP Printer. If you see it listed, right-click on it and choose "Delete" or "Remove Device.”
  • Open up the run command with the "Windows Key + R" key combo.
  • Type printui.exe /s and click OK.
  • Click on Drivers tab.
  • Look for HP Printer driver. If you see it click on it and click Remove at the bottom.
  • Select OK.
  • Remove all instances of the same.
  • Select Apply and OK on the Print Server Properties windows.
  • Close Devices and Printers.
  • Restart the PC again.
Download and install the printer using HP Smart app
Click here to download the HP Smart app
Update the printer firmware to install the latest updates
Here are the steps:- Click here
Keep me posted.
To thank me for my efforts to help you, please mark my post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
