To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
HP officeJet Pro 9015 is connected by wi fi to my mac book , has always worked but nwoit wont print, the print queue shows the job ion queue but it wont print
@MK0928, Welcome to HP Support Community.
If your HP OfficeJet Pro 9015 is showing as "Ready" but not printing from your MacBook, even though the job is stuck in the print queue, here are some steps to help resolve the issue:
Check Printer Status
  • Make sure the printer is powered on and connected to the same Wi-Fi network as your MacBook.
  • Print a Wireless Network Test Report from the printer’s control panel to confirm connectivity.
Clear the Print Queue
  • On your Mac:
    • Go to System Settings > Printers & Scanners.
    • Select your HP OfficeJet Pro 9015.
    • Click Open Print Queue.
    • Cancel all pending jobs.
    • Try printing again.
Restart Devices
  • Restart both your MacBook and the printer.
  • Power cycle your router if needed.
Reset the Printing System (if issue persists)
This will remove all printers and scanners from your Mac and reset the printing system.
  • Right-click (or Control-click) in the printer list and choose Reset Printing System.
  • Re-add your HP OfficeJet Pro 9015.
Reinstall HP Smart & Printer Drivers
Check for macOS Updates
  • Go to System Settings > General > Software Update and install any available updates.
Try Printing from HP Smart
  • Open HP Smart and try printing a test page or document directly from the app.
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Select "Yes" on the bottom left to say “Thanks” for helping!
Max3Aj
HP Support
1 REPLY 1
  • On your Mac:
Restart Devices
I hope this helps.
Max3Aj
HP Support
