macOS 12.0 Monterey
Since last week I have had problems to print, because appear a message Low Memory and cancel the job... I don't know why, because it was working very well. What can I do?
1 REPLY 1
Try printing the job at a lower resolution. The print job may just be too complex for the amount of memory this printer has.
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
