HP DeskJet Plus 4122 All-in-One Printer
Okay here's the problem the printer is offline for some reason and when I try to get it to work on the Internet it's saying something about that it can't connect or can't do anything about it and I try to plug it up and it's not wanting to work I don't understand the problem here it keeps saying stuff like oh you need something but it won't tell me what it needs
1 REPLY 1
@jasonloythomas
Welcome to the HP Community --
Unfortunately, "needs something" is not an actual error message and is not very description of what is happening.
There is likely a solution.
The following offer of help is based on using keywords in your message.
Offline Condition
Although the printer appears to be switched on, it does not communicate with other devices on your network.
Consider >> Restart All
Restart Everything, including the router that controls your network
Next,
Offline - Known solutions, presented in the order to be completed / considered
  HP printer is offline or not responding - Windows / Mac
Section “Advanced Troubleshooting” > Solutions specific to Windows / MacOS / HP Smart (Printer Unavailable)
AND
Troubleshoot a Wi-Fi connection to an HP printer
Next...
NOTES
If the printer won't connect to the Internet,
Check Web Services
If the printer won't print,
Check / reinstall the full driver printer software
Printer - Web Services
Web Services is used to connect the printer to the Internet in general with the added "bonus" of having to connect to HP Services at the end of that journey.  Web Services then recognizes the printer and hands it to whatever service is "next".  For example, Web Services might hand your printer to ePrint, Instant Ink, or certain Cloud services.
Troubleshooting Web Services - Start here
HP printers - Cannot connect to Web Services
What else?
  • Web Services might be sensitive to your DNS setup.
  • The source of the Web Services issue could be your Internet Service Provider,
  • The source of the Web Services problem could be an interim connection at that moment,
  • The source of the Web Services problem could be tangled within the Printer connection setup
Printer - Printer Software
 Remove / Install the full driver printer software
If not done by this point...
Restart everything, including the router that controls you network.
Can't stand it?  At least restart the printer and the computer and any device you can stand to be without for a short time.
Next,
Run Windows Updates  --  If any updates are installed, Restart the computer and log in.
Next,
Printer - Full Feature Software - Install
If you have not done so, consider
  • HP Full Feature Software / Full Driver printer software - supports printing and scanning from the web, printing in in other software and programs (for example, Word), and provides access to the full range of Printing Preferences / Shortcuts.  The full driver adds at least two shortcuts to the Desktop:  Printer Assistant and HP Scan.  If the printer model includes built-in Fax hardware, the software supports the setup and use of the Fax driver.  No Sign-in required.
If the full driver printer software is (already) installed but not working,
  • Uninstall any printer software from Control Panel > icon view > Programs and Features
  • Restart the computer and sign in.
Next,
  • Check (for the Printer) in Devices and Printers  > If found, Right-Click Printer and Remove -- If any changes are made, that is, you remove anything, Restart the computer and sign in.
Next,
  • If using a printer USB cable between the printer and the computer, disconnect the cable before installing the printer software.
Watch video to learn how to install printer software
 HP Deskjet Plus 4152 |4155 |4158: Download & Install HP Full featured Software on a Win 10 computer
OR
Continue...
  • Download and Save the Full Feature Software installation package or the Easy Start Software
Details Page - Driver - For your Printer
>>> Full Feature Software - Web Pack Installation Package - Information - Download  <<<
HP Easy Start Printer Setup Software – Offline Use Only
Installation
  • Open File Explorer
  • Navigate to the folder in which you saved the installation file  (likely Downloads)
  • Right-Click on the installation package and “Run as Administrator
  • If using a printer USB cable between the printer and the computer, connect the cable when instructed (near the end of the installation).
  • After the software is installed, Restart the computer and log in
The installation of the full driver adds at least two shortcuts to the Desktop:
Printer Assistant
HP Scan
>>> Open the Printer Assistant > tab Scan Manage Scan to Computer Enable
Example - Windows - Full Feature Software - Installed in Programs and Features
Programs_and_Features_Printer_Desktop_Icons_11Programs_and_Features_Printer_Desktop_Icons_11
References / Resources
 Product Specifications for the HP DeskJet Plus 4122 All-in-One Printer (7FS77D)
Section Connectivity
Ports
1 Hi-Speed USB 2.0
Wireless capability
Yes, built-in Wi-Fi 802.11a/b/g/n
Storage device and direct print support
Storage devices not supported
HP Printer Home Page - References and Resources
Learn about your Printer  - Solve Problems
When the website support page opens, Select (as available) a Category > Topic Subtopic
NOTE:  Content depends on device type and Operating System
Categories Alerts, Access to the Print and Scan Doctor (Windows), Warranty Check, HP Drivers / Software / Firmware Updates, How-to Videos, Bulletins/Notices, Lots of How-to Documents, Troubleshooting, Manuals > User Guides, Product Information (Specifications), Supplies, and more
Open
Thank you for participating in the HP Community --
People who own, use, and support HP devices.
Dragon-Fur
