HP OfficeJet Pro 9135e All-in-One Printer
My 9135e won''t print on paper lesss than 5.5 inches high.  This means I can't print a single checjk from quickbooks.  Is there a fix for this?
2 REPLIES 2
Specs state that minimum size through the mp tray is 5 inches. This will likely be a custom size so you can only print through tray 1 (also referred to a bypass tray or single sheet tray). So you will need to create a custom paper size on the printer that matches your media and then load that media in tray 1 and tell your program to print from tray 1
https://www.hp.com/bd-en/products/printers/product-details/product-specifications/2101610330
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
@Maineac99
Welcome to the HP Community --
Tray 1 should support additional sizes.
I can provide information on what the printer should be able to do -- I cannot fix your print program settings.
Perhaps the EWS / printer side of the Paper Size / Type setup needs to be checked / updated.
Check and adjust paper size and type settings:
On the printer itself - the touchscreen printer control panel after changing paper or opening / closing tray
OR
Use the Embedded Web Server (EWS) as described in the user manual to check / adjust Paper Size and Type.
Remember to make note of your printer's PIN password inside the front door.
User Guide > Page 2 - Item #6
You'll need the password to get into some of the settings in EWS.
Write the password on a paper and stick it on the printer until your change it or memorize it.
EWS – Tray and Paper Management
Original EWS
Open your Browser > Type / enter the Printer IP address into URL / Address bar
Tab Settings > Preferences > Tray and Paper (Management)
Select / Adjust settings for Paper Size / Type
Model and EWS version Dependent:  Advanced section
Click Apply to save changes
OR --
This printer
Alternate Style EWS
Section Paper > Trays > click on Tray to configure
And (in addition and as available)
Section Print > Default Print Options > Select default tray
Example - EWS - Tray and Paper - "new" format EWS
EWS_9135_Tray_and_Paper_2EWS_9135_Tray_and_Paper_2
References
Specifications - Paper Sizes / Types
Borderless PrintingYes, on photo paper only, up to 8.5 x 11 in (US letter), 210 x 297 mm (A4)
Media Size (facet)Letter; A4; Legal; B5
Media Sizes Custom (imperial)Tray 1: 3 x 5 to 8.5 x 14; 5 x 8.3 to 8.5 x 14 in. Tray 2: N/A
Media Sizes Custom (metric)Tray 1: 76.2 x 127 to 215.9 x 355.6 mm. Tray 2: N/A
Media TypesTray 1: Plain Paper, HP Photo Papers, HP Matte Brochure or Professional Paper, HP Matte Presentation Paper, HP Glossy Brochure or Professional Paper, Other Photo Inkjet Papers, Other Matte Inkjet Papers, Other Glossy Inkjet Papers, Thick Plain Paper, Light/Recycled Plain Paper, HP Tri-fold Brochure Paper, Glossy. Tray 2: Plain Paper
Media Weight Recommended (imperial)16 to 28 lb (plain paper); 60 to 75 lb (photo); 20 to 24 lb (envelope); 90 to 110 lb (card)
Media Weight Recommended (metric)60 to 105 g/m² (plain); 220 to 280 g/m² (photo); 75 to 90 g/m² (envelope); 163 to 200 g/m² (card)
Media Weights Supported, By Paper Path (Imperial)16 to 28 lb (plain paper); 60 to 75 lb (photo); 20 to 24 lb (envelope); 90 to 110 lb (card)
Media Weights Supported, By Paper Path (metric)60 to 105 g/m² (plain); 220 to 280 g/m² (photo); 75 to 90 g/m² (envelope); 163 to 200 g/m² (card)
and
Data Sheet - HP OfficeJet Pro 9135e All-in-One Printer
References / Resources
HP Printer Home Page - References and Resources
Learn about your Printer - Solve Problems
Categories: Alerts, Troubleshooting, Ink & Paper, HP Software / Drivers / Firmware Updates , Setup & User Guides, Product Specifications, Account & Registration, Warranty & Repair
Open
 Product Home - Printers
 Enter the device type and model name of your HP product
OR
 Select a saved product from HP Account Dashboard
OR
Thank you for participating in the HP Community --
People who own, use, and support HP devices.
Click Yes to say Thank You
Question / Concern Answered, Click my Post "Accept as Solution"
Dragon-Fur
