To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
HP OfficeJet Pro 8025e All-in-One Printer
macOS 11.0 Big Sur
I just bought a OfficeJet Pro 8025e.  I have two Mini Macs.  A 2012, 2018 and a new MacBook Air.  I can print black and white only on the 2012 Mac.  Why do I need to use the HP Smart app to be able to download drivers and print in color? The HP Smart app won't work on my 2012 Mac.  Is there a way to get the printer to print color on my 2012 without the smart app?  My 2012 is still an important computer for me and  works great!  if I knew this would be an issue I probably would not have bought the printer.  Any help would be appreciated.    Thanks
3 REPLIES 3
Hi @Phil1989,
Welcome to the HP Support Community
I'd like to help!
I understand you are unable to print in color from your mac.
To assist better-
1) Does the copy print out the same way?
2) What's the application you are trying to print from? Have you tried printing from a different application or device?
While you respond to that, let's print a Print Quality Diagnostic page -Post the Print Quality Diagnostic page here so we can help you further.
You may also refer to this document with steps to fix the " Print Quality Issues" issue applicable to your printer -  Print Quality Issues
Try updating mac and printer firmware
To update the printer's firmware, refer - HP Printers - Updating or Upgrading Printer Firmware
 To update your Mac, try these steps - How to update the software on your Mac
You may also add the AirPrint printer to the Mac printer queue
Add the Air Print printer to the Mac printer queue
Confirm you are using Air Print by adding the printer in System Preferences.
  1. Click the Apple menu, click System Preferences, and then click Print & Scan or Printers & Scanners.
  2. Check if your printer name displays in the Printers list, and then do one of the following steps.
    • If your printer is listed, remove and re-add the printer to confirm it is set up for Air Print. Click the printer name, click the minus sign "-" to delete the printer, click the plus sign "+"click Add Printer or Scanner, click the printer name and then continue to the next step.
    • If your printer is not listed, click the plus sign, click Add Printer or Scanner, click the name of your printer, and then continue to the next step.
  3. Confirm Air Print or Secure Air Print displays in the Use or Print Using menu, and then click Add.
  4. Open a document or photo, click File, and then select color and click on print
Let me know how this goes
Click the “Yes" on the bottom right to say “Thanks” for helping
I am trying to print from Word but also pictures from Preview and color from things on the internet using Safari.  In the Word test document that I did today I typed different lines in black letters, red and blue and they all printed in black.
I updated the HP drivers and software as shown in the instructions and link in your reply.  The update was successful.
After the update I printed out a picture and it was still black and white.  I printed out the WP test page I created with different color letters and it still came out black and white.  (see attached)   I looked for an settings page for the printer for color choices but couldn't find one.  What's next?
Have you tried adding the printer with airprint?
Let me know!
