HP OfficeJet 7110 Wide Format ePrinter - H812a
printer showing connected but during print PRINTER 7110 SHOWING ERROR - PROBLEM IN PRINTER OR INS SYSTEM
1 REPLY 1
Hi @ARJUN47,
When your HP OfficeJet 7110 Wide Format ePrinter is displaying an error message like "Problem in printer or ink system," it typically indicates that there might be an issue with the printer's hardware or ink system. Here are some steps you can take to troubleshoot and potentially resolve the issue.
Check for Hardware Issues:
  • Ensure that the printer is properly connected to the power source and turned on.
  • Make sure that all cables and connections are secure and not damaged.
  • Check for any visible physical damage on the printer, like paper jams or foreign objects inside.
Inspect the Ink Cartridges:
  • Open the printer cover and check the ink cartridges. Ensure they are properly installed and securely seated.
  • Replace any empty or low ink cartridges with new ones.
  • Clean the contacts on the ink cartridges and inside the printer using a lint-free cloth or alcohol swab.
Reset the Printer:
  • Turn off the printer, unplug it from the power source, and wait for a few minutes.
  • Plug the printer back in and turn it on.
  • Try printing a test page to see if the error is resolved.
Update or Reinstall Printer Drivers:
  • Sometimes, outdated or corrupted printer drivers can cause errors. Visit the HP website to download and install the latest drivers for your printer model.
Perform a Hard Reset:
  • A hard reset can often resolve hardware-related issues. To perform a hard reset, unplug the printer from the power source and wait for about 60 seconds. Then, plug it back in and turn it on.
Check for Firmware Updates:
  • Ensure that your printer's firmware is up to date. Check the HP website for firmware updates and follow the instructions to install them if available.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
