To resolve issues with error EBS00P0013 on HP Smart App: Click here to view.
Officejet 8500
Power button, auto answer and "!" flashing.  Will not shut down. Only power cycles when pushing power button
@JustBMW
Thank you for posting on HP Forums,
Riddle_Decipher, is at your service.
The blinking/flashing lights represent a specific error on the printer, you should be able to identify what the error is using the blink code, to help you out, here's a link with the details on what each blink represents:
The lights on the front of the printer indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. Blinking lights can indicate error conditions. They might also indicate that the printer is starting up, processing a print job, or charging batteries.
FOR DETAILS & FURTHER INSTRUCTIONS, USE THIS LINK: CLICK HERE
(By the end of this article all the issues should be resolved)
If you feel I was helpful, simply click on Accept as Solution to help the community grow,
That said, I will have someone follow-up on this to ensure you've been helped,
Just in case you don't get back to us within 24 - 48 hrs, and have a good day, ahead.
Riddle_Decipher
I am an HP Employee
Learning is a journey, not a destination.
Let's keep asking questions and growing together.
3 REPLIES 3
@JustBMW
Riddle_Decipher
I am an HP Employee
FIX
Thank you for your help!
The solution this time was to reinstall driver software.  I will use the codes if the printer wants to misbehave again
John
@JustBMW
I'm glad you got this issue sorted out
Do visit our HP Forums and drop us a message anytime you need help
Thank you
KrazyToad
I Am An HP Employee
