JP office jet 6700 premium
Hi!
Anyone know what power cord I need for this printer?
Tried one that said it was compatible however it didn't work.  So I'm looking for the specs on the correct cable.
Thank you!
2 REPLIES 2
@DGW1
Please look at Power Cord section on the following link and order the right one (right voltage and plug):
     http://partsurfer.hp.com/Search.aspx?searchText=CN583A
Note: You can use part # to check other online stores such as Amazon, normally it is cheaper.
Regards.
BH
Thanks for your help BH, however when I clicked the link there was no 'power cord' section.
I eneteted my serial # as the site asked and was not able to track down anything on power cords.
If you have have any other suggestions, I'm open to them!
Thank you!
