HP 8600 officejet
I have an HP 8600 office jet printer that consistently loses connection to the wireless network whenever it printer goes into power saver mode (LCD screen goes dark and power button slowly flashes). When I power off the printer and turn it right back on, it connects to the network again.  This is very frustrating as it defeats the purposes of having a wireless connection. I think if I can just leave the printer fully powered it will solve the problem but the setup screen does not allow the option to not go into power saver mode (max time powered while waiting is 15 min).
I should add I also have Spectrum Hogh speed cable Internet with their dual band router, although the printer cannot see the 5G band.
I also have a HP 6480 that also looses connection. Is it an HP problem? Anyone have good luck with the Epson WorkForce printers?
6 REPLIES 6
These settings are for setting up your wireless or wired printers to:
* Stay connected to your router
* Fix printer ‘offline’ status
* Wake from sleep mode
* Speed up wireless printing
While DHCP is convenient, devices such as printers (wired and wireless) should always be assigned a static (fixed) IP address manually to avoid conflicts on your wireless network and MUST be outside the DHCP address range of the router. This is because printers are the only external devices that do not have the ability to automatically interrupt the router for a new DHCP address once the least time expires.  Again, do not have the printers static IP within the DHCP range of the router as this is against Networking 101 rules and will confuse the router.
After setting the static IP, the computer(s) must be updated under Printer Properties/Ports to show a Standard TCP/IP port with the printers’ new static IP address.
1. Set a static IP in the printer outside the DHCP range of the router (check your manual).  This Static IP is important as DHCP IP addresses will change upon different power up sequences of your devices.  You always want your printer to come up with the same IP address all the time.  See how to do this here:
http://www.watchingthenet.com/linksys-tip-assign-static-ip-address-to-printer-while-using-dhcp-on-yo...
This is for Linksys routers but can be used for all routers. Verify your DHCP range and change this first if needed.  Then after setting the static IP in the printer, the computer(s) must be updated under Printer Properties/Ports to show a Standard TCP/IP port with the printers IP address.
To see why this problem exists and how to fix it, watch this video here for Windows.   Scroll down for MAC information.
https://www.youtube.com/watch?v=ZEqvUKxWmq4
How to set a Standard TCP/IP port.  This is important.
a.    Click Start/Devices and Printers.  Right click on your HP Printer.  Select Printer Properties.  Select the Ports tab at the top.
b.    Select Add Port.  Select Standard TCP/IP Port.  Select New Port.
c.    Follow the Add Port Wizard.  Under Printer Name or IP Address, input the Static IP address you just set from the above information.  Example:  192.168.1.15.  The IP address will be copied under Port Name.  This is OK to leave this alone or you can put in your Printer Model.
d.    Select Next and Finish the Wizard.
If you create a TCP/IP port without a static IP above, you may lose your TCP/IP connection and have the same issue. This is because your network has powered up differently giving you a different DHCP address to the printer that does not match the TCP/IP address above.  This could occur at anytime just like the video shows.
For MAC PCs perform the above Static IP setting in the router and then watch here on how to perform your IP setting for MAC computers.
https://www.youtube.com/watch?v=A5tNFjEBDOw
By performing the above, the printers Embedded Web Server (EWS) will now work all the time by going to your Printers Static IP address in your browser.
2. Verify in the printer that 'Auto Off/Sleep/Energy Saving Mode' is disabled and/or the System Mode Time Out is set to zero (0) if your printer supports this.  Use the Embedded Web Server (EWS) by going to the printers IP address in your browsers address bar, click Settings Tab/Auto Off, or use the Printer Assistant, Printer Home Page (EWS). Also check your Printer Properties. This feature is automatically disabled when the printer is connected to a computer or mobile device, a network, or a fax line (if supported).   However, you may not find this setting.
3. If the printer supports and has IPv6 enabled, disable IPv6 in the printer.
4. Make sure printer is plugged directly into a wall outlet and not into a UPS, power strip or surge protector. This may cause the printer to intermittently drop offline and disconnect.
5.  Make sure your printer and router are at least 5 feet apart from each other.
6.  Check the HP web site for your printer to see if there is a Firmware Upgrade that affects the wireless operation.
Additional steps to be taken if you continue to have the problem (if they are posted)…
Click on the link to subscribe and get the latest video uploads: https://goo.gl/y4Rcn1 This tutorial shows how to add a printer using the IP address for macOS 10.12 Sierra. The added printer is sometimes more stable and also helps to resolve some print and scan issues such printer offline. HP ...
Printer offline issues can happen because the IP address of the printer keeps changing. This video explains how that can happen and what to do to fix it. For more tech tips, check out https://www.linearthoughts.co.uk . 00:00 - Introduction 00:18 - The Problem and Why it Occurs 03:47 - Solution ...
So I added a new TCP/IP port and manually setup a static IP address, 192.168.0.3 to match what the printer is currently set at.  The printer worked. However when the printer goes into power saver mode, the printer goes offline.  The only way to get it to work again is to turn the printer off, then restart and the computer can print to the 8600 printer. Is there a way to keep the HP printer from going into power saver mode?
I should add, I have Spectrum Internet and they do not allow access to the router so I cannot change any addresses.
Yes you should be able to access the Spectrum gateway.    Download their manual and you can do it yourself.
Call Spectrum and tell them you want the DHCP addresses in the unit set to 192.168.0.100 thru 192.168.0.150.  Now you have plenty of static IP available.
If not you need to have Spectrum put that gateway in full bridge mode and buy your own high quality router that you have full control over and connect it up.
Spectrum has not been of any help. The tech support claim even they do not have passwords to access myrouter. I plan to buy an Asus router during theblack Friday sales coming up. They have good reviews on CNET and are reasonably priced.
What I do not understand is we just started having this problem about 3 months ago when Spectruminstalled a dualband router. Prior to that it was working fine.  I bought HP8600 because I also have an HP J6480 that would also goes offline all the time. The 8600 was a great improvement until recently.  The J6480 woud be offline even before the dual band router was installed.
Just ran across this excellent and comprehensive write-up. Kudos. I have just one quibble: While I agree that it is preferable to configure a static ip, if for whatever reason  a printer needs to access DHCP, then most routers will allow a DHCP reservation using the printer's MAC address. This has the effect of keeping the printer at a specific IP while still allowing DHCP. I came across an admittedly rare situation (there may be others) where for whatever reason the printer (an OJ 8740) would lose connection to the network if set at a static IP but would not lose connection to the network if the printer was set for DHCP. I never did work out exactly what was going on, but this workaround effectively solved the problem.
