Windows 11 Support Center. -
- HP Community
- Printers
- Print doesn't work, "waiting for printer to become available...
08-08-2020 04:08 PM
This requires remote assistance. Please reach out to the HP Support in your region for further course of action.
Hope this helps!
TEJ1602
I am an HP Employee
08-24-2020 11:09 AM
I have followed all these instructions and I can't print anymore (only the scan works).
I have exactly the same problem than SGS12 :
- A new Mac with no USB port
- An USB connector from USB-C to USB
- No Airprint for my HP Officejet 2620
So I have a printer which perfectly worked on my previous Mac and which is now useless due to a software problem!
It's unacceptable ! If for each software update you have to buy a new printer, it's an ecological disaster !
09-22-2020 09:50 PM
i have the same problem. scanner works fine - copier works and earlier it printed out a test page - but that isn't working now either. keeps waiting for the printer to become available"
spent two hours on this so far - big waste of time at this point.
10-24-2020 09:19 AM
Hi ... as a non-techy person I managed to get it to work ... but found that the printer is now much slower with stop/start action. It seems that the choice of printing options has changed also with Fast, Draft & Black& White now gone. The Colour prints were agonisingly slow. I'm not sure whether anything that can be done with improving the speed to its previous levels. Is it to do with Airport processes?
10-26-2020 02:51 AM - edited 10-26-2020 02:52 AM
I have been following various threads with regard to this issue. I have the same issue on Macos Catalina 10.15. I have tried all the suggested solutions without success. I tested the printer on a Windows pc and it works perfectly. So in my opinion it is an issue with the HP drivers on Catalina. Just like some other people in this forum who are/were loyal HP fans, my loyalty will now be transferred to a competitor where I believe I will receive much better support.
10-27-2020 11:17 PM
I have followed this thread and another on "filter" issue for my Deskjet 3054 and I have also spent over two hours trying to fix this. Scanner works, copier works but the printer will not work with my Mac on OS 10.15.17. HELP! I am also ready to give up on HP as a source for printers.
10-28-2020 02:23 AM
Hi,
I've had same issues (because my printer is connected through usb) and this thread solved it:
If the issue continues on your Mac after resetting the printing system, take these final steps to remove any currently installed printer drivers. These steps don't apply to AirPrint printers.
From the menu bar in the Finder, choose Go > Go to Folder. Type /Library/Printers/
and click Go.The Printers folder opens. Choose Edit > Select All, which selects all items in the Printers folder.
Choose File > New Folder with Selection, which puts all of the selected items into a new folder named New Folder With Items. To save storage space, you can delete this folder.
The printer started immediately to print out after step 3.
Hope this helps!
