To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
HP DeskJet 4152e All-in-One Printer
Hey all-
I have an HP Deskjet 4152 printer and it never fails that when I attempt to print a document, the printing starts but then suddenly the printer stops and I have all the lights on the control panel blinking, and there isn't a specific error code just E blinking. I don't know what to do, it ends wasting a lot of my paper and I am about ready to buy a new printer. Has this happened to anyone else Anyone have any ideas?
Thank you in advance!
1 REPLY 1
Hi @JutMSmith,
Thank you for posting your query. I will be glad to help you.
Thank you so much for reaching out and sharing your experience — I’m really sorry to hear about the frustration you’ve been having with your HP DeskJet 4152. I completely understand how discouraging it can be when a printer stops mid-job, wastes paper, and leaves you without clear information on what’s going wrong.
While this issue isn’t extremely common, it can happen, and typically points to a general printer error, which could be related to a paper jam, cartridge issue, or a temporary internal error.
Please try the steps shared below, this should help solve the issue.
Please remove the Cartridges from the Printer if possible, and try a Hard Reset. Do keep us posted to help you better
** Hard reset :
1. Turn the printer on if it is not already on.
3. With the printer turned on, disconnect the power cord from the rear of the printer.
4. Unplug the power cord from the wall outlet.
5. Wait at least 60 seconds.
6. Plug the power cord back into the wall outlet.
NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
7. Reconnect the power cord to the rear of the printer.
8. Turn on the printer if it does not automatically turn on. The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
9. Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
HP Smart App: Please uninstall the HP Smart app --> restart the Device, Wi-Fi router and printer --> reinstall it back and add the printer.
HP Firmware Update: Please update the Firmware from the link. This will help to update the firmware on the printer or devices.
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, as it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
VikramTheGreat
HP Support
