Envy 5540
I was recently able to print remotely from my laptop.  But I can't now.  So I tried hard wiring from the laptop to the back of the HP Envy 5540 printer but still can't print.  Solution to being able to print while hard wired?  We will start there.
Thank you.
Salming
1 REPLY 1
@Salming
Welcome to HP Forums,
This is a great place to get support, find answers and tips. Thank you for posting your query. I'll be more than glad to help you out 🙂
To diagnose this issue, try to copy a document. If copy works fine, this may a software issue.
To fix this issue, uninstall and reinstall the printer driver.
Use the method below to remove all existing print drivers installed on your PC:
1.) In Windows, search for and open Apps & features.
2.) Select your HP Printer
3.) Select Uninstall
4.) In Windows, search for and open Printers &Scanners
5.) In the Printers &Scanners windows look for your HP printer. If you see it listed right-click on it and choose 'Delete' or 'Remove Device'
6.) Open up the run command with the "Windows key + R" key combo.
7.) Type printui.exe /s and click Ok. (Note: there is a space in between “printui.exe” and “/s”)
8.) Click on the "Drivers" tab
9.) Look for HP Printer driver. If you see it Click on it and click Remove at the bottom
10.) Select Ok
11.) Select Apply and Ok on the Print Server Properties windows
12.) Close Devices and Printers
Once the drivers are removed, to download and install the software and driver: Click here
Once the printer is connected using USB connection, you can convert to wireless: Click here
Roopa-S
I am an HP Employee
