Windows 11 Support Center. -
- HP Community
- Printers
- Printer losses wireless connection when inactive for a while...
05-27-2017 08:31 AM
Printer losses wireless connection when printer goes into sleep mode, I think. It works if I shut printer down and restart it. After a while I will get message that printer is off-line when I try to print again later.
Solved! Go to Solution.
05-27-2017 09:43 AM
These settings are for setting up your wireless or wired printers to:
* Stay connected to your router
* Fix printer ‘offline’ status
* Wake from sleep mode
* Speed up wireless printing
While DHCP is convenient, devices such as printers (wired and wireless) should always be assigned a static (fixed) IP address manually to avoid conflicts on your wireless network and MUST be outside the DHCP range of the router. This is because printers are the only external devices that do not have the ability to automatically interrupt the router for a new DHCP address once the least time expires.
After setting the static IP, the computer(s) must be updated under Printer Properties/Ports to show a Standard TCP/IP port with the printers’ new static IP address.
1. Set a static IP in the printer outside the DHCP range of the router (check your manual). This static IP is important as DHCP IP addresses will change upon different power up sequences of your devices. You always want your printer to come up with the same IP address all the time. See how to do this here:
http://www.watchingthenet.com/linksys-tip-assign-static-ip-address-to-printer-while-using-dhcp-on-yo...
This is for Linksys routers but can be used for all routers. Verify your DHCP range and change this first if needed. After setting the static IP, the computer(s) must be updated under Printer Properties/Ports to show a Standard TCP/IP port with the printers IP address.
To see why this problem exists and how to fix it, watch this video here for Windows. Scroll down for MAC information.
https://www.youtube.com/watch?v=ZEqvUKxWmq4
How to set a Standard TCP/IP port. This is important.
a. Click Start/Devices and Printers. Right click on your HP Printer. Select Printer Properties. Select the Ports tab at the top.
b. Select Add Port. Select Standard TCP/IP Port. Select New Port.
c. Follow the Add Port Wizard. Under Printer Name or IP Address, input the Static IP address you just set from the above information. Example: 192.168.1.15. The IP address will be copied under Port Name. This is OK to leave this alone or you can put in your Printer Model.
d. Select Next and Finish the Wizard.
If you create a TCP/IP port without a static IP above, you may lose your TCP/IP connection and have the same issue. This is because your network has powered up differently giving you a different DHCP address to the printer that does not match the TCP/IP address above. This could occur at anytime just like the video shows.
For MAC PCs perform the above Static IP setting in the router and then watch here on how to perform your IP setting for MAC computers.
https://www.youtube.com/watch?v=A5tNFjEBDOw
By performing the above, the printers Embedded Web Server (EWS) will now work all the time by going to your Printers Static IP address in your browser.
2. Verify in the printer that 'Auto Off/Sleep/Energy Saving Mode' is disabled and/or the System Mode Time Out is set to zero (0). Use the Embedded Web Server (EWS) by going to the printers IP address in your browsers address bar, click Settings Tab/Auto Off, or use the Printer Assistant, Printer Home Page (EWS). Also check your Printer Properties. This feature is automatically disabled when the printer is connected to a computer or mobile device, a network, or a fax line (if supported) you may not find this setting.
3. If the printer supports and has IPv6 enabled, disable IPv6 in the printer.
4. Make sure printer is plugged directly into a wall outlet and not into a UPS, power strip or surge protector. This will cause the printer to drop offline and disconnect (yes verified!).
5. Make sure your printer and router are at least 5 feet apart from each other.
Additional steps to be taken if you continue to have the problem (if they are posted)…
05-27-2017 09:43 AM
05-28-2017 10:00 AM
Thank you very much Provost. I appreciate your help.
I manually (on the printer) set the printer IP to 192.168.1.5, which I think is outside the dynamic range of my Actiontec V1000H router, then updated this IP address in the HP Printer driver app on my computer. It has been working perfectly for two days. There have been multiple sleep states and restarts of computer and printer.
Thanks again for your help.
