HP Officejet Pro 8610 e-All-in-One Printer
Printer failure. There is a problem with the printer or ink system
1 REPLY 1
@JHS2025, Welcome to the HP Support Community!
Thanks for reaching out about your query regarding an "There is a problem with the printer or ink system" error message!
We're thrilled to have the opportunity to assist you and provide a solution.
Try these steps:
Check for obstructions in the carriage path
Clear obstructions from the carriage area inside the printer.
With the printer on, disconnect the power cord from the rear of the printer.
Open the door to access the carriage inside of the printer.
Look in the carriage path for debris such as crumpled paper or dislodged labels, and then remove any that you find.
”言籌,쭈=한-墨 `
Use your hand to move the carriage to each side, making sure it moves freely. If the carriage is stalled or docked to one side of the printer and you cannot move it, continue with these steps.
Close the carriage access door.
Reconnect the power cord to the rear of the printer, and then turn the printer on.
Hope this helps!
Take care, and have an amazing day!
Did we resolve the issue? If yes, Please consider marking this post as "Accepted Solution" and click "Yes" to give us a helpful vote - your feedback keeps us going!
Regards,
ZOEY7886
I am an HP Employee
