To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
My HP Officejet 4652 printer got unplugged without being turned off and now I can't get to turn back on.
When I plug it in the screen will flash once and go black again.
1 REPLY 1
@Sowulo_1111, Welcome to HP Support Community.
When an HP OfficeJet 4652 printer is unplugged abruptly and won’t power back on—only flashing the screen once—this usually indicates a power-related issue, either with the power supply, internal power components, or a firmware fault caused by the sudden loss of power.
Here's a step-by-step approach to troubleshoot this:
Basic Power Reset
  • Unplug the power cable from both the printer and the wall.
  • Wait 1–2 minutes.
  • Press and hold the Power button on the printer for 30 seconds to discharge any residual power.
  • Plug the power cable directly into a wall outlet (avoid power strips or surge protectors).
  • Plug it into the printer and try powering it on again.
Check the Power Module
  • Ensure you're using the original HP power adapter (output: 32V / 12V).
  • Check the adapter for:
Burnt smell
Fraying
Loose plug ends
  • If you have a multimeter, you can test if it’s outputting the correct voltage.
Note: Faulty adapters are a common cause of this issue. If you suspect it’s dead, replacing the power adapter is often a solution.
Try a Different Outlet
  • Move the printer to a known working outlet in a different room.
  • This rules out circuit-specific issues or surges affecting that outlet.
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Select "Yes" on the bottom left to say “Thanks” for helping!
Max3Aj
HP Support
