Windows 11 Support Center. -
- HP Community
- Printers
- Printer power problem
10-17-2023 01:22 PM
Product: HP Color LaserJet Pro MFP M281fdw
Printer turned off and couldn’t be turned on. I moved plug to different outlets which made no difference. I then changed the power cord, and printer came on. Then next day, printer was off again and couldn’t be turned on. thanks for the help!
2 REPLIES 2
10-17-2023 09:44 PM
Most likely the power supply is failing. I had a customer with that exact same issue. Printer would go off, she would unplug for a day, it would come back on for a while then fail again. Eventually it would not come on at all.
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
Ask the community
