Other
Problems :
1)  The rollers could not pull papers from the paper tray.
2) The Power Chord is very loose.  Sometimes it drops down itself from the printer.
Kindly rectify the problems, and replace the power chord immediately.
The printer was delivered just yesterday
2 REPLIES 2
Reference: Invoice No.[Personal Information Removed]; Invoice Date: 16/01/2022
Customer Order No.[Personal Information Removed]; PO Ref : 101300001(;64186;
Docket No.[Personal Information Removed]
just yesterday the HP Deskjet 2332 AiO – HP HSN / SAC Code:84433100 Serial No: [Personal Information Removed] Printer was delivered to me with the following problems:
  •  the printer is non-functional in the sense that the rollers are not pulling any papers from the paper tray;
  • the power chord is so loose that it sometimes automatically drops down itself from the printer; Kindly arrange to rectify the above problems and replace the power chord immediately
Hi, thanks for posting, however this is a user to user support forum. In terms of getting warranty repairs you will need to contact technical support. Phone Assist Worldwide | HP® Official Site
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
