Windows 11 Support Center. -
- HP Community
- Printers
- Printer problem with HP OfficeJet Pro 9020
06-06-2022 04:33 AM
I am having a problem with my HP OfficeJet Pro 9020 to get it to print as I keep getting the message "Output Bin Full".
I have tried to clear this message as the output bin is clear and there are no paper jams.
06-10-2022 01:03 PM
@Adair3
Welcome to the HP support community.
I understand that you are getting Output Bin Full error message. I am glad to assist you.
You might have to perform a semi-full reset on the printer.
The reset instructions are specific for your printer and performing those steps on a different printer may brick the device.
I am sending you a private message with the steps to reset the printer. Please check the mailbox icon at the top-right corner of this screen.
I hope this helps resolve this issue completely.
To thank me for my efforts to help you, please mark my post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
