HP Photo Smart
macOS 10.13 High Sierra
I have been printing on UPS labels for years, now all of a sudden it will no longer print on UPS labels.  Messages says "Paper size  Mismatch.  It easily prints on FedX labels (same size but not as thick).
Thanks
1 REPLY 1
@BARBGOR, Welcome to the HP Support Community!
Which model HP Photosmart printer do you use?
Which application are you trying to print from?
What is the label size and type you are using to print on?
For now, let us try these steps:
Reset the printer
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Wait at least 60 seconds.
  3. Reconnect the power cord to the rear of the printer.
  4. Turn ON the printer, if it does not automatically turn on.
  5. Wait until the printer is idle and silent before you proceed.
Note: HP recommends connecting the printer directly to a wall outlet rather than a surge protector or a power strip.
Update the printer firmware
Click here to know different methods of updating printer firmware.
Also, check for any software updates on MAC
Click here to know how.
Check the print settings on your MAC
Refer to this document.
Let me know how this goes.
If you feel my post solved your issue, please click “Accept as Solution”, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
KUMAR0307
I am an HP Employee
