To resolve issues with 0xb90c05a4 error on your OfficeJet series: Click here to view.
Smart Tank 7300
Other
After running through various methods of troubleshooting, the printer still will not print double sided. I do own this device, but for some reason I am unable to link it to my account because the serial number will not register.
1 REPLY 1
Hi @mmrash96,
Thank you for posting your query, I will be glad to help you. I have shared a link that should help.
Print on both sides of the paper (Windows)
CAUTION:
Do not print on both sides of envelopes, photo or glossy paper, or transparencies, or with paper lighter than 60 g/m2 (16 lb) or heavier than 105 g/m2 (28 lb) to prevent paper jams and printer damage.
Open the document, and then click File > Print.
Select your printer, and then click Printer Properties, Preferences, or Printer Setup.
From the print settings, select the option for a two-sided print job. Menu options vary by printer model.
Click the Layout, Features, or Finishing tab. Click the Print on Both Sides drop-down menu, and then select Flip on Long Edge for a book or Flip on Short Edge for a tablet .
Print on both sides menu in Windows
Click the Printing Shortcut tab, and then select the Two-sided (Duplex) Printing shortcut. Click the Print on Both Sides Manually drop-down menu, and then select Flip on Long Edge for a book or Flip on Short Edge for a tablet .
Two-sided printing shortcut in Windows
Click OK, and then click Print.
If the printer does not automatically print the other side, remove any remaining paper from the input tray to prevent issues.
Remove the printed pages from the output tray, and then reload them into the input tray.
For bottom-loading input trays, load the pages print-side up with the top edge towards the printer (book ) or bottom edge towards the printer (tablet ).
Reloading the pages for duplex printing with a bottom-loading input tray
For top-loading input trays, load the pages print-side down with the top edge towards the printer (book ) or bottom edge towards the printer (tablet ).
Reloading the pages for duplex printing with a rear paper tray
Click Continue to complete the two-sided print job.
To change back to one-sided printing, reopen the print settings and remove the selections for two-sided printing.
I hope this helps.
Rachel571
HP Support
Sneha_01- HP support
