HP Color LaserJet Pro MFP M283fdw
My printer won’t power on. I’ve tried unplugging it, changing the outlet, holding the power button down for 20 seconds. Not sure what else
2 REPLIES 2
Hi @lytlelb
If your HP Color LaserJet Pro MFP M283fdw printer is not powering on despite trying basic troubleshooting steps, here are a few additional things you can try.
  • Check power connections: Ensure that the power cable is securely connected to both the printer and a functional power outlet. You can also try using a different power cable if available.
  • Reset the printer: Locate the power button on the printer and press and hold it for about 60 seconds. This will drain any residual power and can help reset the printer.
  • Check the power adapter: If your printer uses an external power adapter, verify that it is functioning correctly.
  • Test with a different outlet: While you mentioned changing the outlet, it's worth trying another one just to be sure there's no issue with the power source.
  • Remove additional connections: Disconnect any USB cables or Ethernet cables connected to the printer. Sometimes, a faulty cable can prevent the printer from powering on.
  • Check for physical damage: Inspect the power cord, power socket on the printer, and any visible components for any signs of physical damage.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
I have seen a couple of these units with failed power supplies. Parts are to offered by HP so you need to look to used parts suppliers on ebay.
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
