HP Color LaserJet Pro MFP M283fdw
When I am printing more than one separate job, I have to wait more than 5 minutes to print the next item.  If I try sending another job right away or before it allows me to, it will not print and the status says "printing," but it never prints.  i have to cancel all jobs and wait more than 10 minutes for it to clear so I can try printing again.  How can I correct this so it's not taking forever to print more than one job?
1 REPLY 1
Hi @JDK66,
I see that you are facing an issue with slow printing on your printer.
A) Please follow the steps below to perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If the issue still persists, uninstall the printer software by following the steps from this link and restart the devices.
D)  Install the printer software by clicking on the link again and let me know if that resolves the issue.
Note: Enable Bluetooth for an HP Smart app setup: Enable Bluetooth on your computer or mobile device so that HP Smart can detect the printer during the setup.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
