Brand new. Setting my Hp Smart tank 210 via the wireless set up.  Print head errors show one Printhead not correctly functioning. I’ve reset, re-inserted, made sure all products coverings are off, re-aligned. Can’t seem to get past this, it won’t print.
3 REPLIES 3
Hi @NoSeNada,
Thank you for posting your query, I will be glad to assist you.
I understand you're experiencing an issue with your new printer that has a printhead error.
I apologize for any inconvenience this may have caused, I'm here to help you today.
Please follow the steps below to fix the issue.
A) Perform a power drain.
 1) Unplug the power cord from the printer & wall.
2) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
3) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
4) Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Power on the printer
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) Refer to the steps on this link to further troubleshoot and also refer to the below video link to make sure you have remove all the packaging from the printer.
https://www.youtube.com/watch?v=uKm_sADuElo
D) If the issue still persists, refer to the steps on this link to restore factory defaults and let me know if that resolves the issue.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a great day ahead!
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
I did all the steps and nothing worked. Further, I attempted to return and or exchange the printer to Office Depot and they would not take it back telling me because I installed the ink cartridges it was not returnable.  How can I see if the printer works if I don’t install the print heads? Crazy!
Hi @NoSeNada,
I am sorry to hear that the above steps did not help much but i do appreciate your efforts in performing the troubleshooting steps.
As you have exhausted all the possible troubleshooting steps to fix it. We appreciate your understanding and patience.
I've sent you a private message with the instructions to get in touch with the HP phone support to assist you further. In order to access your private messages, Click the Private message icon on the upper right corner of your HP Community profile Next to your profile Name, you should see a little blue envelope, please click on it or simply click on this link
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
