HP Office Jet Pro 8600 Print, Copy, Scan
When printing the last sheet of paper in the document feeder tray, the paper mis-fed inside of the printer, near the ink heads.  Once I removed the obstruction, the unit shows the following message:  "There is a problem with the printer or ink system. Turn printer off, and then on. (which I did numerous times, along with unplugging the unit). If the problem persists, contact HP."
1 REPLY 1
@BGaskell
Thanks for joining HP Community!
I suggest you do a Hard Reset on the printer
(1) Turn the printer on, if it is not already on.
(2) Wait until the printer is idle and silent before you continue.
(3) With the printer turned on, disconnect the power cord from the rear of the printer.
(4) Unplug the power cord from the wall outlet.
(5) Wait at least 60 seconds.
(6) Plug the power cord back into the wall outlet.
NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
(7) Reconnect the power cord to the rear of the printer.
(8) Turn on the printer, if it does not automatically turn on.
The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
Refer to this document: https://support.hp.com/us-en/product/hp-officejet-pro-8600-e-all-in-one-printer-series-n911/4322914/... for resolving printhead issue.
Keep me posted, how it goes!
If the information provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Have a great day!
Cheers:)
Raj1788
I am an HP Employee
