Windows 11 Support Center. -
- HP Community
- Printers
- Re: Problem with printer head.
05-30-2021 01:37 PM
Error message on printer reads: There is a problem with the printer or ink system.
I've turned off/on, removed ink cartridges and replaced. Print head is not removable.
Bought a solution online to clean print head, followed video, couldn't do it. Time to replace printer?
06-02-2021 06:07 AM
Hi @Corabelle,
I'd like to help!
If you have already performed the steps from the document Error Indicates Faulty Printhead and the issue persists, it could be a hardware failure.
Please reach out to HP Support in your region regarding the service options for your printer.
If you are having trouble navigating through the above options, it's most likely because the device is out of warranty. If yes? please send me a private message with the region you are contacting us from. Check next to your profile name, you should see a little blue envelope, please click on it.
Hope this helps!
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
