Windows 11 Support Center. -
- HP Community
- Printers
- Re: Problem with printer or ink system
05-07-2024 06:19 PM
Printer display indicates " problem with printer or ink system" and to contact HP if turning off and back on doesn't fix the problem. That did not work. I replaced all ink cartridges and it also did not fix the problem. same error message appears every time I reboot the printer.
05-09-2024 10:58 AM
Hi @PapaLuigi,
I see that you are facing an issue with your printer that has an ink system error.
A) Please follow the steps below to perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) If the issue still persists, refer to the steps on this link to further troubleshoot.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a good day
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
